both analog and digital out from Radeon graphics card?
Discussion in 'Desktop & Laptop Computers Forum' started by TorAtle, Dec 29, 2002.
  1. TorAtle
    TorAtle
    I got an adaptor with my Radeon 7500 that allows me to get a standard VGA out to the plasma. However I have ordered a projector as well and I was wondering if there exist an adaptor or cable that splits the digital and analog signals into two connectors - one DVI and one VGA.
    Does anyone know?
  2. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    Unfortunately it's not possible to run an analog and a digital display off the DVI-I port simultaneously. The framebuffer will write to either the RAMDAC or the TMDS transmitter, but not both at the same time.
    Your card probably supports dualhead output though - is it the AIW 7500? Perhaps your best option would be to use the DVI link for the projector then just run a standard S-Video feed to the plasma.
    MuFu.
  3. TorAtle
    TorAtle
    thanks for the answer - although not the one I wanted to hear! It is indeed the AIW7500. So the only option then is to buy a new card with dual outputs..is there one in the Radeon family perhaps?
    (s-video input is already in use)
  4. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Most of the newer Radeon family are dual head with vga and dvi. the 8500, 9000, 9500 and 9700 for sure, Iuse a 9000 with the vga feeding my pj and dvi with an adapter feeding a small tft. Its also got svhs out.
