boston micro's
Discussion in 'Home Cinema Speakers' started by derekrcross, Dec 7, 2001.
  1. derekrcross
    derekrcross
    Feb 20, 2001
    442
    19
    hello all
    looking for some advice im thinking about getting some new speakers 4 boston micro 90x
    1 boston micro 90c
    2 boston micro vrs
    1 rel Q-100E
    i will be using them with a denon 3802 im upgrading from kef cresta's has anyone got these boston speakers as they sound great and seem a high build quality or advice on other small speakers as the cresta 3 are just to big and i can't stand the colour any more (cherry)
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    You could try the Defintive Technology Pro Cinema series (80, 100 or 200, depending on budget). The Pro Cinema 80 pack retails for £950, and had a very good review in HCC a while back. We have them in our demo room and they are the best i've heard in their price and size range.
    Why are getting rid of your Cresta's? They are lovely speakers.
  3. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    East Yorkshire, England
    +171
    Hello Derek,
    I don't have the Bostons myself, but have had a good listen to them, and they are great for the size, when used with a good sub.
    They are expensive here in the UK, so have a look at
    http://www.mediacheckpoint.de
    Only 323DM each (£103) for the 90x, about £123 for the 90 Centre, so the money saved here means you can buy a bigger Sub :)
    Good luck,
    Mark G.
  4. Noman
    Noman
    I have a similar setup
    3802
    4 x Micro 90x
    1 Micro 90c
    Rel Q150E
    and I use the Gallo Nucleus Micro for back surround
    I have used the Micro 90:s for appr 3 years and have been totally satisfied.
    They play clean and loud, superb for movies of any kind.
    Using the High level input on your Rel sub and running the Denon 3802 in Direct mode also gives you a very good sound for stereo music.
    Relative to the size of the speakers they are very, very good
    Some people say the bigger the better, and if this is true I should concider trying the Micro 100x for front L & R for a slightly "richer" sound in stereo.
  5. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    My mix n match speakers included the Boston VRS Micro rears which I thought were exceptional and I only changed them on aesthetic grounds.
    I still have them if you are interested.
    Ian
  6. Doctapaul
    Doctapaul
    Hi, I have a pair of Micro 90x'x and a pair of Micro 80's. Can anyone tell me where I can buy wall mount brackets for them pls? (Ideally in silver)
    Ta!:smashin:
