Boston Acoustics Speakers
Discussion in 'Home Cinema Speakers' started by common, Oct 1, 2001.
  1. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
    I have been offered a good deal on some Boston 90x sat's and a PV75 sub. Does anyone have any experience of these ?
    Also can you use another 90x as a centre or is there a dedicated sat centre ?
    thanks
  2. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    The matching Boston centre is the 90C as I don't think the 90X is shielded.
    There is a review of the Boston setup with a REL subwoofer in the Home Cinema archives. I have a mix 'n match system which includes Boston Micro VRS rears. I have been quite happy with them but will change shortly as I have had them three years and it will save me dusting them.
    Value depends on how good the deal is.
    Regards
    Ian
  3. Noman
    Noman
    Brilliant for it´s size. I have the Boston Sub (75W) and there is the only weak point if you like playing on very high volume.
    Sounds great though on moderate levels.
    I have a setup with 2 90x and a 90c in front and 2 small infinity reference in the back powered by an "old but still going strong" Denon AVR 2700.
    I have friends who has payed 3 times as much for their systems that reacts with nothing but envy when they listen to my setup....
    /Anders
