Quantcast
  • You may not reply to archived adverts. Once they have been archived, they are no longer active and are here for reference only.
For Sale Boston acoustic VR1 Reference series
cookeblade
Rating - 0%
0   0   0
Joined
Aug 27, 2016
Messages
25
Reaction score
Points
4
Location (town/city, country)
Folkestone
I have for sale a pair of Boston Acoustic VR1 Reference Series tower speakers in used condition.
COLLECTION ONLY!!!
VR series has three floor speaker systems (VR1, VR2, VR3) and central channel system. All systems of the series differ by very high sensitivity - not lower than 94 dB. Identical LF/MF drivers are made by Deep Channel Design technology, aimed to increase dynamical reserve of the drivers: the magnet has an elongated form and is equipped with a hole for equalizing the pressure under dustproof cap. An aluminum dome of the tweeter is equipped with Amplitude Modification Device lens, which corrects polar pattern at extremely high frequencies. An aluminum plate is attached to a steel magnetic screen (Magnaguard) of the tweeter for a heat sink. Magnetic shielding of woofers is implemented by compensating magnets. Inside the synthetic-muted body there is a horizontal strut. The bass-reflex port is on the rear panel. VR1 are installed on plastic supports with spikes. On the crossover's PCB there are first ordered filters for LF/MF drivers and third ordered one for the tweeter. Also there is impedance correction circuit, consisting of electrolytic capacitor and resistor with dissipated power of 25W!
Sound. The sound of Boston Acoustics VR1 is dynamical, punchy and "convex". The system conquers by its temperament, never allowing any slackness or disruption. At the bottom there is elastic, movable, well-read bass of medium depth. Minimum of schematics is in musical images; sound is accurate and juicy. The feeling of a bit increased contrast is probably caused by very careful but cautious rise at high frequencies, so there are almost no reasons to speak of characteristic emphasis on sizzling sounds. Great power reserve allows you to handle volume control absolutely freely without hurting sound quality. Breadth of panorama as if hides the depth of musical stage, but this is from the category of the smallest nuances. Boston Acoustics VR1 is the sample of powerful, dynamical, moderately deep system for any musical and theatrical tasks.
System type2-way
Enclosure typeBass-reflex
Frequency response ± 3dB46 - 20000 Hz
Nominal impedance8 Ohm
Amplifier Requirements15 - 200 W
Sensitivity (2.83V/1m)93 dB
Tweeter25 mm (1 in.)
Woofer2 x 165 mm (6.5 in.)
Dimensions (H x W x D)915 x 229 x 267 mm / 36.02 x 9.02 x 10.51 in.
Weight19 kg / 41.8 lbs.
n0chex
Rating - 100%
261   0   0
Joined
Oct 31, 2003
Messages
8,049
Reaction score
794
Points
Age
54
Here on AVF
Do you have the original boxes?
n0chex
Rating - 100%
261   0   0
Joined
Oct 31, 2003
Messages
8,049
Reaction score
794
Points
Age
54
Here on AVF
I don't suppose you pass Liverpool/Manchester anytime?
