Right, if anyone's interested...
Big screen browsing, iPlayer, open/close Blu-Ray from remote
iPlayer
Install
iPlayerSetup_alpha1.5.msi - Google Project Hosting . This will give you iPlayer within MCE, works brilliantly. Only thing you may need to do first is to upgrade your WMP security components (if you can't stream anything this is the giveaway)
Security component upgrade [must be done in Internet Explorer]
Open/close Blu-Ray from remote
Download and extract
NirCmd - Windows command line tool to the root of C:\Windows
Right click on your desktop and create a new shortcut, using the following target:
Open
Code:
C:\Windows\nircmd.exe cdrom open
Create another shortcut, for
Close
Code:
C:\Windows\nircmd.exe cdrom close
If you have more than one drive, append the drive letter to the command, e.g. C:\Windows\nircmd.exe cdrom open E:
Big screen browsing
Download and install
Kylo Browser . Based upon Firefox, so can save passwords etc. and has several zoom setting options. Would recommend disabling the onscreen keyboard within settings as it doesn't seem to accept letter entry via the MCE remote
and therefore gets in the way, but that's the only downside I've found. This will take your desktop resolution, which is excellent for a proper MCE setup (50hz within Media Centre, 60hz desktop) and means that websites like Youtube won't be jerky as a result of this setting (might still be crap due to low quality video though). Have found this a much better solution than Macrotube as you can see all videos available.
Auto 24hz (23.976hz) switching for TMT5 within media centre
So this is the grail I suppose!
Download and install Display Changer -
12noon
I chose to install both 32bit and 64 bit variants so you'll need to base your shortcuts based on your OS.
This will form the basis of a shortcut to go into MCE, to switch from your MCE refresh rate to 23.976hz while using TMT5, and then swap back again once you've finished with TMT5.
Code:
"C:\Program Files (x86)\12noon Display Changer\dc64cmd.exe" -refresh=23 "C:\Program Files (x86)\ArcSoft\TotalMedia Theatre 5\uMCEPlayer5.exe"
Now that's done, time to put it all into MCE!
Media Center Studio
Open this up, and choose the Start Menu option at the top, then the start menu tab.
Some of this is personal preference - I remove the TMT5 and Kylo groups as they're on Extras as well, and I don't see the point in it cluttering up the menu.
I'd also recommend unticking 'Explore' within Extras as it takes up room for not a lot of use.
Click on Application at the top, give the new shortcut a descriptive
Title such as Open DVD.
Copy and paste the shortcut target you created earlier - remembering to just put the Exe path in the Target, and the argument on its own line (you can then delete them from your desktop - only recommend creating them to test they work). You can also assign a custom image. Don't worry about iPlayer and Kylo, their shortcuts are automatically created and added to the extras folder.
Once done,
Save your changes by clicking on the floppy icon at the top.
Then, start Media Centre.
At this point, go into your Extras library at the top. Right click on the shortcut that you want at the
end of this list, and choose
Add to Start Menu. Repeat this process for the rest, remembering that they'll be added right to left.
Once done, sit back and admire your handiwork.
The only thing I haven't been able to solve is that if you open your drive, and pop a blu-ray in, TMT5 will autoplay it using it's standard settings (e.g. desktop refresh rate, not 23hz). Workaround is to open the TMT 23 shortcut, then use eject within there. Don't do as I did and try and remove the registry entries for autoplay blu-ray, as they're very difficult to resurrect, even after reinstalling TMT5. The eject options will work fine for standard DVDs within media centre though!
