Bose speakers making odd noise?
Discussion in 'Home Cinema Speakers' started by TopMeTom, Sep 21, 2003.
  1. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,228
    +261
    have been doing some room renovating...
    Anyways when I put everything back in place I noticed my speakers were making a odd noise,sos I checked all my connections and found that the centre speaker terminal on me old amp was buggered,does not grip wire.
    I now have it resting in the hole(the wire)but noticed on my right speaker in the background there is still this odd noise.
    Could this all be due to the amp or something more sinister?(i.e.
    speaker knackered??)
    I know bose are not everyones cup of tea but I like 'em,so don't really want to replace unless I have to.....
    Many thanks for your help,
    Phil :suicide: :eek:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    try swopping rears around if odd noise moves then its the speaker. if not its the amp. one thing about BOSE a replacement cube is easy to get (expensive) some earlier ones were repair able so once you know what is causing fault get it in for repair at local dealer. (i would get the amp repaired any how!
