bose lifestyle
Discussion in 'Home Cinema Buying & Building' started by joeter, Apr 25, 2007.
  1. joeter
    joeter
    i am travelling to miami soon and am thinking of buying a bose lifestyle system. i was in orlando last year and could not beleive how much cheaper they are. now that the euro is so good against the dollar they are even better value.
    question 1. should i buy one. ?
    question 2 will it work. i know i need a 110v converter and i have one, but will the tuner work, and will it play region dvds.?
    little help.:confused:
  2. RossH
    RossH
    No, by the time you've converted it you'd be just as well buying it over here!
  3. joeter
    joeter
    ok thanks i think ill leave it
