Bose AM15
Discussion in 'Home Cinema Speakers' started by sunlink, Sep 22, 2003.
  1. sunlink
    sunlink
    Looking to purchase a set of AM15's with upgrade and wanted to get some feedback on performance, especially playback of music.
    Steve:)
  2. scarty16
    scarty16
    Jul 1, 2003
    1,033
    +89
    YOu picked teh wrong place to get feedback, (almost) everyone on here hates BOSE, personally I like them, they are small and do the job well.
    IMHO They are more suited to Movies than music.
  3. Nobber22
    Nobber22
    Jun 6, 2002
    2,977
    Berkshire
    +109
    Er Steve, I think you'll find this is NOT the place to come looking for positive reviews of Bose kit. :nono: Nothing (rightly) gets a bigger slating round here than Bose; it's overpriced, poor quality and sells through marketing power instead of genuine sound appeal. You can do SOOOO much better for the money. :)
  4. sunlink
    sunlink
    Nobber/Scarty,
    Thanks for the feedback. Any ideas on a better sounding but similar setup.
    I currently have a set of Tannoy Precision speakers which I find excellent. My missus is badgering me to go smaller. I am very reluctant. Any help would be greatly appreciated.
    Steve:)
  5. nathan_silly
    nathan_silly
    Cue my penis reduction joke!:rotfl:
    I don't have any experience with them Tannoys, but any decent sub/system will outperform Bose tat in every regard. Kef Eggs at £600 for a stater- proper two way drivers, excellent build, and sound very good for the money (although don't match bookshelf speakers, which is to be expected)
  6. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,117
    83
    Over the Hill & Far Away
    +119
    Or have a look at Anthony Gallo.. small but sound great :)
    www.anthonygallo.co.uk
    I am just saving to buy the centre speaker before I will have finished my speaker revamp !
    Matt
  7. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    You've definitely picked the wrong group to get some Bose luvin'! But then again, you've picked the right group to get the right speakers (and that daft Bose nonsense out of your head for good!) for your system.
    Personally, the only small speakers I would consider are Anthony Gallo, I would even consider the AG's if I wasn't after small speakers too! But I am a reseller and likely to be biased!!!
    If the other half wants smaller, but not smallest, maybe just to wall mounting size I would consider the latest kef eggs (not so hot for music IMO), the B+W VM1's (look and sound brilliant) or persuade the missus that see-through glass speakers are as good as going smaller as you don't notice them that much and what you do see is very good looking...... then go out and get a complete set of Waterfalls!
  8. sunlink
    sunlink
    Thanks everybody for the helpful feedback. Bose are deffinitely not a goer now.
    What is the most suitable Anthony Gallo system for both Music and Home Cinema?
    Steve:confused:
  9. nathan_silly
    nathan_silly
    I would keep what you've already got. Don't replace them with Bose or Gallos.
  10. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,853
    2
    +3,225
    Are you single Nathan? what a women has decided decor wise is- almost- set in stone. Sunlink may be able to retain the larger speakers but only at the expense of his house.
  11. nathan_silly
    nathan_silly
    If you pay for the mortage, I think you've got every right to enjoy your hobby.
    It's strange that she'll probably blow hundreds of pounds of YOUR money on shoes/handbags- yet when you buy a subwoofer or something for yourself all hell breaks loose.
    Be a man.
  12. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,117
    83
    +119
    On the Gallo front.. what is quite popular is 3 Divas across the front with micros 2/4 for surrounds. (Or some have used 2 Divas and a Due or if you are really rich 3 Dues :) )
    You can pretty much mix and match as your budget dictates..now I also use the Gallo mps-150 sub.. but others have gone for Velodyne SPL etc etc.. again the sub choice is down to budget and WAF constraints !
    HTH
    Matt
  13. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    Both the Micro and A'Diva are fairly popular but need very careful partnering and setting up otherwise they will sound terrible.
    If that is the way you wish to go, forum sponsors AV Sales.com are Gallo dealers so send a Private Message to Liam McLaughlin asking for his best price and you may get a pleasant surprise.
    If it were me I would look at the JM Labs Sib & Cub setup available from here which is not only a lot cheaper than a Gallo system but probably better as well.
  14. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,078
    notts.
    +63
    Hi Ian
    I think you were posting the link to hifi bitz who are doing the jm labs sib &cub for 599 quid which is a bargain.(link didnt work)
    Gonzo.
  15. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    My wife quite likes the big speakers as they are real wood veneer and look nice - also they sound good!
  16. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    It does now - thanks
  17. Uncle Dicky
    Uncle Dicky
    Have you considered upgrading your wife instead of the speakers?
    You may be able to find a good quality one that works alongside your larger speakers in harmony!
    Seriously though, keep away from the Bose, have a look at Miller & Kreisel instead.
  18. avanzato
    avanzato
    Jan 21, 2003
    1,879
    Norfolk
    +60
    Do those JM Lab speakers look as good in real life as they do in the pictures?
  19. sunlink
    sunlink
    Gents,
    Thanks for the good advice, however far to expensive to try and upgrade the wife. Therefore, I am going to stick with my Tannoys (they are superb with both music and Home cinema) and spend the money saved on decent bi-wire cables. One of the main drivers towards small speakers, was determined by the fact that I am building a purpose built 8m x 8m extension (home cinema lounge) that incorporates an Ingelnook fireplace. I have 52 inches above the mantle piece to accommodate my screen (48 inches high) leaving 4 inches to try and house my 8 inch high centre speaker.
    I am going to start another thread for ideas on how to house it, currently I am considering housing it in the ceiling at an angle, but would be greatful for any other suggestions.
    Steve ;) ;) ;)
  20. RastaCat
    RastaCat
    Sep 8, 2003
    32
    If this extension you speak of is going to be purpose built, why are you compromising speaker location?
    I know if I had the opportunity to build a room from scratch, I certainly wouldn't be compromising on the most important aspects such as speaker positions and equipment housing etc.
    Just MHO of course. ;)
    RastaCat
  21. sunlink
    sunlink
    Rasta,
    Apart from being an entertainment room, I still have to accommodate the wife, hence the Inglenook fireplace and the subsequent centre speaker dilemma.
    Happy to discuss
    Steve:confused:
  22. Stellavision
    Stellavision
    Apr 7, 2003
    2,190
    Southsea, UK
    +76
    My wife's opposition to my AV always came because she think's our lounge should look like a lounge / living room and is not the theatre I try and create in it.
    I seriously believe that if we had the space to build a purpose built cinema room I would be let loose to build it to however I felt appropriate. Think you need to show her who's boss mate!:devil:
