Bose Acoustimass 5
Discussion in 'Home Cinema Speakers' started by Mr A, Mar 3, 2001.
  1. Mr A
    Mr A
    Hello
    Does anyone have one of these systems. If so waht do you think of it? how big is your room and what are the connections do you get true 5.1 i.e separate sub feed at line level or is it just taken off the main speakers??
  2. Ars longa, vita brevis
    acoustimass five is stereo only, two double cubes and a sub.
    for 5.1 you'd need the 6 or above.
    Also, the .1 is not from the lfe channel, and the speakers decide what they cannot handle, routing that to the sub
    Assumption is the mother of all errors
    member formerly known as hank hill, then Jesus H
    but got bored so it became some latin sh*t
