Bose Acoustimass 10 or Q Acoustic 7000i
Discussion in 'What Speakers Should I Buy?' started by P13FACE, Dec 14, 2016.
  1. P13FACE
    P13FACE
    Jun 8, 2016
    119
    Worcester
    +33
    Hello all,
    I'm going to purchase a new shiny 4k enabled amp to go with my new 4k TV, and while i'm there i'm thinking about upgrading my speakers too. I'm currently using 7 year old KEF 5.1 speakers.
    I'm looking for speakers which are small but produce a quality sound, which has led me to either Bose AM10, or QA 7000i speakers.
    Which of these two do you feel are better value for money?
  2. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,438
    What Kef speakers do you currently have (make/model). Unless they are the very basic Kef eggs (1005 model) then neither of the speakers you mention are going to represent a significant improvement over your current speakers. I would steer clear of the Bose as they tend to be over priced and under perform.
  3. P13FACE
    P13FACE
    Jun 8, 2016
    119
    Worcester
    +33
    Hi mate,
    Thanks for the response.
    The KEF speakers I have are;
    KEF KHT-2005
    Would there be little point in upgrading these?
  4. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,438
    The QA speakers are basically the same level of speaker as the Kefs you have so would not really represent an improvement in sound quality. They may sound different which you may perceive as an improvement but I suspect they will sound very similar. You would probably need to double your current budget for the QA speakers to really get an improvement.
    As for the Bose they tend to be high end prices but budget performance from my experience of them.
  5. P13FACE
    P13FACE
    Jun 8, 2016
    119
    Worcester
    +33
    Thanks for the help, do you have a example of a set of speakers that would be noticeably better?
    Thanks mate
  6. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,438
    Something like the Monitor Audio apex range.
