BOSE AC 6 Upgrade with VCS 10
Discussion in 'Home Cinema Speakers' started by BoomBoom, Aug 27, 2004.
  1. BoomBoom
    BoomBoom
    Hi all,
    I have a BOSE AC 6 and would like to upgrade the Centre speaker as the sound is a little flat, I want to get a BOSE speaker for the 'WAF' and have been looking at the VCS-10.
    I know many will say dump the BOSE and get suchandsuch but I can't do that, I am stuck with them.
    1) What I want to know is can I cannot the VCS-10 to the AC-6 Sub or does it need to run directly from the AMP?
    2) Also do you know if you can get a wall bracket for the 10? I want to mount it below my Plasma.
    3) I will be mounting all 3 front speakers at ear level should the FL & FR line up perfectly with the Centre?
    thanks in advance.
  2. z5461313
    z5461313
    Sep 18, 2001
    1,694
    +255
    I have a Bose AM15 and had some problems with the center channel but it does not bother me now after some things I changed, which are
    1. Buy a high quality optical cable running from DVD player to amplifier. I have a Nordost White Light cost 50 pounds and its really improved things alot. Base is controlled better, the speakers are more musical and DVD's more detailed. Well recommended
    2. Buy a Pioneer dvd player which has a vocal enhancement feature. This seems to have made the center channel more intelligible but I do not know how it works. I have it set to medium on my Pioneer 575a and dialogue is clear for me
  3. BoomBoom
    BoomBoom
    Thanks very much.
    I will give that cable a go. Do you know if Pioneer do a decent DVD Player which has DVI output? and ofcourse it can't be toooo pricey...I don't want much do I ?
    :laugh:
  4. sapkan
    sapkan
    Jul 8, 2004
    496
    +4
    I wanna know the answer to 1) too. PLS
