bose 35 set up
Discussion in 'Home Cinema Buying & Building' started by markbigears, Jan 6, 2004.
  1. markbigears
    markbigears
    Dec 30, 2003
    516
    chalk, Kent
    +18
    can anyone help me, whats the best way to set up a bose 35 with a plasma for best picture and audio quality? Many thanks, Mark
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    Does plasma have component input what plasma and what else is connected?
  3. markbigears
    markbigears
    Dec 30, 2003
    516
    chalk, Kent
    +18
    plasma is the th42pa20b and yes it has component in, thing is im not sure if the bose has? looking at various set ups most seem s-video. If you know if the bose has component in it would be appreciated if you could drop me a post. Also, any idea on audio inputs. Im linking a VHS recorder and a DVD recorder up at a later date too. Mucho thanks, Mark
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    BOSE lifestyle 35 will output component via an adapter which uses both the composite and S-video connections.
    Means you cant use the video switching but can get best DVD quality Adapter should be in the Box you will need a 3 RCA>3RCA component cable and you have to change the LS setup to output component.
    Audio for VCR use 2 phono to the VCR input on the BOSE head unit and DVD-R either the same way or via optical input Send video direct to PA20 scarts in both cases!
    PS can i ask where you bought the system?
  5. markbigears
    markbigears
    Dec 30, 2003
    516
    chalk, Kent
    +18
    bought the plasma for £2995 and bose £2950 both from john Lewis. Why do you ask? Many thanks for the advice on setting up. Much appreciated.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    Well they should really have explained all this to you, I deal with BOSE quite often and the package you got for £6k is very good buy. Personally i would reconmend the plain PW6 with a LS35 unless you dont have sky, cable, or freeview (fewer speakers you see. Also means the BOSE syetm is fully utilised for sound.
  7. markbigears
    markbigears
    Dec 30, 2003
    516
    chalk, Kent
    +18
    Im sure they will explain to me, but my wife did the deal, so i havent been down to them yet. No havent got sky or freeview and also wanted the extra speakers just so that, say for news on TV, i didnt want it coming through the bose speakers. When you say "fully utilised for sound" whats does that mean? have i bought the wrong plasma? Many thnks so your advice, im a bit of a novice at this AV lark!
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    NO fully utilised means always USE BOSE even if just for the news, East enders etc for TV sound you would need to run a pair of stereo phono leads to the Bose from TV (plasma) audio out.
    PS sounds like your wife got a cracking deal mark.:)
