Quantcast
Bose 321 multiregion hack
Stuart Wright
AVForums Founder
Staff member
* Press the 9, 4, Shuffle, Stop and Mute buttons on your remote control
To Set a Specific Region
* Press the Open, Stop, Shuffle buttons on your remote control to Open the disc tray
* Press the 1 button on your remote control for region 1, 2 for region 2, and so on
* Press the Enter button on your remote control
T
Toni57
Just wondering if anyone has actually done this with success. I don't seem to be having any luck.
Thanks.
daveyjay
Might have to update software first-Bose technical dept.will send you a disc or you could join Bose 321 Yahoo group and download software from files page.
T
Toni57
I called Bose today, and the tech rep told me all I could do was to send it in and have the region changed, but Region 0 was not an option. *cough*
Thanks for the info...I'm off to Yahoo.
