Quantcast
Bosch WAN28100GB
wacky60
I have had this washing machine just under 2 years and only really use the dark wash at 30 degrees, which i understood to be 4kg load. Recently it has not been spinning the clothes as dry as before and i'm having to spin them agin, so i had a service guy call who said i should use the cottons wash at 30 degs and i wasn't putting a big enough load on, but i've never used 7kg as there are only 2 of us, but i agreed to try it as he said he was almost certain i wasn't putting enough load in. It's exactly the same & i have to keep using the spin only again which is wasting electric. Any help or ideas would be much appreciated. Thank you
larkone
It sounds like the machine may have a balance issue so shutting down the higher spin speeds. Could be a failed suspension damper. Sounds like the engineer is talking horlicks.
Somebody
Have you tried overriding and increasing the spin speed by pressing the RPM button at the beginning of the wash?
