Would appreciate any advice/suggestions on this issue I'm having with a Bosch SMS461W00G dishwasher...
Started using my new Bosch dishwasher in early 2019. Not had a dishwasher before and was reasonably impressed with cleaning performance with my chosen cleaning program - until earlier this year when cleaning performance gradually began to drop off. I then started to use and extra half a cleaning tablet which helped for a few months - but in hindsight, just delayed the inevitable because now, cleaning performance most definitely isn't what it was, even with the extra half tablet. In particular, tea stained mugs are nearly always left with a few (usually faint) stain 'rings' whereas that just didn't happen in the first year of usage - and it's getting gradually worse. Some other items sometimes now also come out less-than-clean too. Results are patchy. Frustrating thing is, I've not been doing anything different compared to last year. And the machine is used only three times a week on average.
I use WHICH? recommended dishwasher cleaning tablets, ensure the salt and rinse aid settings on the machine are correctly adjusted for local water hardness and I've done all the usual things to try and resolve this problem:
- Cleaned dishwasher (3 times in past year with propitiatory cleaner (once last week) and twice recently with distilled vinegar)
- Filters cleaned every 3 or 4 washes but they are barely dirty because I don't load visibly dirty items into the machine (I get the pee taken out of me for that)
- Always stack items thoughtfully
- Even used a top-end Finish dishwasher tablet recently (recommended by Bosch) which actually gave slightly worse cleaning results than my usual tablets.
- Dismantled the pump protection cover and examined pump, which was spotless (as was the entire machine - looks like showroom new)
- I don't use an automatic program that senses level of dirt then adjusts water usage and/or time accordingly. Tried it once - no good because everything placed in dishwasher is pretty clean to begin with so machine doesn't sense dirt and decides little cleaning is required.
- Some of the the tea stained mugs are new, some old so the problem isn't related to damaged surface finishes of crockery.
