Borked Speaker
Discussion in 'Home Cinema Speakers' started by Lithian, May 5, 2003.
  1. Lithian
    Lithian
    Jan 16, 2003
    38
    9
    Edinburgh 3
    I was listening to some music at -10 yesterday and was hearing a strange sound, i shrugged and ignored it. Then a song i liked came on and it went up to -5.
    A definate 'farp' 'farp' 'farp' was being overlayed onto the sound.
    I turned the volume down and noticed that the 'farp' was only coming from one speaker. My front left AE aegis evo 3.
    So i take the cover off and see that the midrange is moving around a lot more than the bass. Hmm, maybe its just the music i thought.
    So i check out the front right, its not suffering from the same problem, they are set at the same volume as each other.
    I dont have a sub yet so the bass is being directed out of these and the aegis evo centre as well.
    But i cant think how this could happen, i could understand a faulty driver not moving enough, but too much?
    It has never been above -5, and has always been slowly increased over the space of 30 mins or so.
    hmm, any ideas?
  2. ditton15
    ditton15
    Oct 20, 2002
    535
    16
    edinburgh
    Is this a screenplay you are writing, or are you taking substances?
    Just a minute, I think I once read a short story by Phillip K Dick in which much the same happened.
    Is it the channel or the speaker? Try swapping the two speakers, or maybe just the two speaker cables.
    ditton
  3. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,905
    I've tried to get my speakers to bork but I can't quite manage it.
  4. bob1
    bob1
    Nov 7, 2002
    4,354
    Sheffield
    +131
    Raw eggs make me bork:eek:
    Sounds like you've killed the speaker,are they under waranty?
  5. Sunday Ironfoot
    Sunday Ironfoot
    Maybe somethings come loose which is making it move more. Anyhow I would second bob1's idea.
  6. Lithian
    Lithian
    Jan 16, 2003
    38
    9
    Edinburgh 3
    Forgive me, i am known to ramble on quite a bit.
    ditton: screenplay - no, substances - i was still hung over, the channel - possibly, i am using the digital out on my nforce2 and i have been having some issues with the sound, crackling with multiple sources etc.
    Ian: I have a 100KV rapid discharge capacitor (dont know why its rated in V, just what it says on the case) which ought to do the trick.
    Bob: raw eggs hmm, you know this how? Yep under warranty, they are only 2 months old or so.
    Sunday Ironfoot: Dosn't look loose, and i would assume it would rattle at lower volumes.
    So i will check it out next time the family are out and i will try swapping the channels.
    Hmm, another long post? oops, i just made it longer :laugh:
  7. Lithian
    Lithian
    Jan 16, 2003
    38
    9
    Edinburgh 3
    Alright, thats me deaf!:smashin:
    I was just listening to some music at reference level and paying a lot of attention to both of the evo 3's.
    I was watching the cones dance about, and noticed that the left (the problem one) was wobbling sideways quite a lot.
    So, what i assume is the problem is that it hasn't been mounted quite straight, not normally a problem except at loud levels where the rubber seal interferes.
    sound like a good theory?
  8. alexs2
    alexs2
    Nov 13, 2002
    13,897
    +1,671
    Definitely sounds damaged to me.....could be that the voice coil has come loose or the cone's mountings...either way,it shouldn't be doing what you describe.
    Sounds like a trip to the dealer/manufacturer.
