Bootable CD? Help!
Discussion in 'General Chat' started by richjthorpe, May 7, 2007.
  1. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    I desparately need to create a bootable CD in order to bring up a DOS prompt on a laptop that only has a CD drive on it.
    I'm getting an "NTLDR is missing" error and want to try and recover the data on the PC.
    How do I do it?
    Thanks,
    Richie.
  2. Singh400
    Singh400
    Feb 21, 2006
    17,850
    Earth
    +3,370
    Any OEM/Retail XP CD will do.
  3. kraiklyn
    kraiklyn
    Dec 18, 2002
    1,202
    +60
    You could always download and run Knoppix, a Linux OS that runs from bootable CD rather than requiring installation.
    Just plug in a external USB hard disc and boot of knoppix, it's likely it will read your non-bootable discs file structire and you can try and copy of the data to the external storage device.
    http://www.knoppix.org/
  4. paul_w
    paul_w
    Feb 13, 2005
    109
    +14
    You might have to go into your bios to make the pc boot from the c or d drive. (Whichever your cd drive letter is) If its not set up that way
  5. Setenza
    Setenza
    Jun 17, 2002
    3,349
    +226
  6. sandstheman
    sandstheman
    Jan 6, 2005
    545
    28
    +49
    If you have Nero Burning ROM installed, you can burn a CD Boot Disk as one of the options
