Boot To CMD
Discussion in 'General Chat' started by Member 328449, Apr 29, 2016.
Tags:
  1. Member 328449
    Member 328449
    Aug 31, 2007
    3,415
    Kent
    +340
    With the help of a very generous forum member I have a CMD program on my computer. Now I would like to get it on a USB stick so I can put it in another computer, and when this is turned on it immediately opens the CMD program full screen.
    Anyone know how to do this? When I search Google it just gives me instructions for how to create a bootable Windows USB stick.
  2. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,394
    Norfolk
    +2,406
    I'm not quite sure what CMD stands for, but generally you can't run a program directly. You need to have the operating system it runs on booting from CD and then just set it up to autorun in the settings.
  3. Member 328449
    Member 328449
    Aug 31, 2007
    3,415
    Kent
    +340
    Command Prompt
  4. Inferno
    Inferno
    Feb 24, 2008
    5,870
    Bedlam, Warrington, Cheshire
    +2,077
    Just go into the BIOS of the computer you want to put it on and set it to boot from the USB stick if the option is there, I have the option in my BIOS but I am not sure its available on all to be honest.
    Or just turn on the other Comp and navigate to the CMD prompt on the stick and click it.
    EDIT :
    Oops, just re read it you want the prompt putting on the usb stick, I will look for you.
  5. Member 328449
    Member 328449
    Aug 31, 2007
    3,415
    Kent
    +340
    I can set it to boot from USB. I just don't know how to make the USB bootable.
  6. Inferno
    Inferno
    Feb 24, 2008
    5,870
    +2,077
    What op system?
  7. Member 328449
    Member 328449
    Aug 31, 2007
    3,415
    Kent
    +340
    Windows 7
  8. Inferno
    Inferno
    Feb 24, 2008
    5,870
    +2,077
    Here is a video on it, too much to be typing ha ha,
    Create Bootable USB Flash Drive using Command...
    Once you have a bootable stick just run cmd off of it.
  9. Member 328449
    Member 328449
    Aug 31, 2007
    3,415
    Kent
    +340
    Although I have a laptop with Windows 10 to create the drive if needed.
  10. Member 328449
    Member 328449
    Aug 31, 2007
    3,415
    Kent
    +340
    See this is what I mean. I did this but it's not Windows 7 I want to boot to. I want the computer to go straight to the cmd program I have had created.
  11. Inferno
    Inferno
    Feb 24, 2008
    5,870
    +2,077
    What are you trying to do?
  12. Member 328449
    Member 328449
    Aug 31, 2007
    3,415
    Kent
    +340
    I have a text based game where players have to type in answers to get to the next screen. This game is in CMD. I want the game to launch automatically when the computer is turned on.
  13. mjn
    mjn
    May 24, 2001
    22,910
    Herts, England
    +11,057
    There is a HP Utility which can create a bootable USB key.
  14. mjn
    mjn
    May 24, 2001
    22,910
    Herts, England
    +11,057
  15. Member 328449
    Member 328449
    Aug 31, 2007
    3,415
    Kent
    +340
    Unfortunately I don't have a CD drive otherwise I could try that.
  16. icemanonline
    icemanonline
    Sep 4, 2006
    7,185
    Edinburgh
    +2,240
    Can't you just install the game on the other PC then f8 and start from cmd?
    Ice
  17. mjn
    mjn
    May 24, 2001
    22,910
    Herts, England
    +11,057
    You don't need a CD drive. Just use a virtual one.
  18. Member 328449
    Member 328449
    Aug 31, 2007
    3,415
    Kent
    +340
    I think I may have solved this. I have just moved the cmd shortcut into the startup folder. Easy as that!
  19. Sniper Ash6
    Sniper Ash6
    Jun 5, 2008
    27,854
    127.0.0.1
    +7,613
    It won't be possible just by plugging the flash drive into the computer for the obvious reason of security. If that were possible then anyone could just write something malicious, chuck it on a flash drive and plug it in to any computer they can reach.
  20. DVD-Man
    DVD-Man
    Jul 24, 2004
    8,580
    Ayrshire, Scotland
    +1,932
    Use rufus to create a bootable USB stick, no CD drive required
  21. Member 55145
    Member 55145
    Jan 18, 2005
    12,079
    +3,481
    sounds to me more like you want an autorun.inf
    A bootable stick wont do anything to the running OS
    Sounds to me like you are just trying a 90's PC prank....
  22. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,394
    Norfolk
    +2,406
    He doesn't seem to have a bootable image though, just a program. Those utilities are designed to put software already set up to boot, such as a CD image, onto a USB key, they won't create an operating system for a program to run in.
    Yeah, if you don't specifically need it to run on any computer with no setup then that's by far the best solution.
