Boost plusnet signal with a sky router?
fizzer25
Moved in with the gf, she has +net. The signal in certain parts of the house is none existant.
Is there a way to boost the signal using my sky router? Or will I be best off spending £20 on a booster?
Morphies
AFAIK you could install a custom firmware on the old sky router, such as DD-WRT and then set it up as a repeater.
This of course depends on your competence and patience.
I personally found it easier to just purchase a repeater :D
mickevh
Have a read of our "using two routers together" FAQ.
Nothing can "boost" wi-fi signals; it's just not possible. In any case, "more signal from the router" is not the best solution.
A primer on how Wi-Fi really works can be found here.
"Repeating" will at least half your Wi-Fi bandwidth (speed) so most people avoid it unless there's no other option. Additional outpost Wi-Fi AP's cabled back to your router is the best option.
gagaga
Similar threads
