Bookshelfs for under £100, Suggestions?
Discussion in 'Home Cinema Speakers' started by vaz.01, Mar 10, 2005.
  1. vaz.01
    vaz.01
    Hello peepz,
    Im a newbie to all this. I have got a cambridge audio a1 amplifier and am looking for budget bookshelfs that give off the most bass.any suggestions would be appreciated.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    try second hand far more bang per buck.....also the position and mounting are important how will they be mounted/located
  3. vaz.01
    vaz.01
    I will either wall mount them or get speaker stands, i was thinking either the mission m71i or gale gold monitor.
  4. Londondecca
    Londondecca
    Dec 21, 2003
    2,105
    +108
    I would go slightly further and say "position and mounting are very important"
    I think the Mission M71's are staggeringly good speakers for roughly £60, they do need decent stands though
  5. OneDesi
    OneDesi
    Mar 10, 2005
    8,542
    Black Country
    +260
  6. superpixel
    superpixel
    I would personally get a 2nd hand pair of B&W DM601s.
    I still haven't heard any other budget bookshelf pump out as much bass and be able to be driven so loud. should **** all over those Missions, Eltax and Tannoys if you like your bass.
    Contrary to Londondecca, I think expensive stands are a complete waste of money for this gear, though wall mounting is a bad idea - just get whatever cheap and cheerful stands you can afford
  7. Londondecca
    Londondecca
    Dec 21, 2003
    2,105
    +108
    There was an interesting demo many years ago where a speaker was hidden and the audience asked to identify the speaker. Most went for a mid range (£500ish) large speaker due to the very deep and impressive bass. It was in fact a Whafdale Diamond on some fancy and very expensive stand.
    If your speakers are not held correctly, you are losing information. I am not suggesting that someone spends £300 on stands for a £80 speaker but in my experience they are an important part of the system.
    Where you place the speakers is of greater importance but that is another issue
