Bookshelf/standmount speakers
Discussion in 'Home Cinema Speakers' started by Knightshade, Sep 20, 2005.
  1. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Toying with the idea of getting bookshelf speakers for my main system as it looks like I may be robbed of my listening room shortly. :thumbsdow Moving to a room that is 18ft x 14ft. I think floorstanders will be a bit much.
    I don't know a huge amount about good standmounts and would like to be educated.
    Cheers All.
  2. SOUNDSTYLE
    SOUNDSTYLE
    Oct 4, 2002
    1,290
    +57
    You can get some good Monitor Audio RS 1s for £250
    Very good sound, but ofcoarse they don't produce as much low down bass as floor standers; They produce just enough bass though.
    Or look for some second hand Monitor Audio GR10s.
    Very high quality speakers which cost (if I remember correctly) about £800 new.
    http://www.ssav.com/stockclearance/stockclearance.html
  3. recruit
    recruit
    Knightshade - i would recommend the new B&W 805S's as for music they are the best standmount speakers i have heard, very dynamic in there presentation and with some real weight to the bass for such a small speaker, i have listened to quite a few different speakers now and owned a few too but for 2 channel music i would not hesitate to recommend..
  4. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Thanks Recruit, Found a local shop that's stocks them. I will take a look.
    It is the 'Signature' series you're talking about isn't it?
  5. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Cheers Soundstyle, useful link.
  6. recruit
    recruit
    Knightshade - It is the new 800 Range which has replaced the older Nautilus series and surpasses the Signature 805 for performance and it is cheaper too.. :)
    www.bwspeakers.com/index.cfm/fuseaction/products.models/Label/Model 805S
  7. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Aha! Thanks.
  8. sonofmoth
    sonofmoth
    Nov 30, 2002
    384
    GR10's are £599 at Sevenoaks at the moment. Awesome speakers :)
  9. Londondecca
    Londondecca
    Dec 21, 2003
    2,100
    +103
    I would also consider speakers such as AE1's, LS3/5a's, Audionote or maybe the kits from Wilmslow Audio
