Bookshelf speakers.
Discussion in 'Home Cinema Speakers' started by JIT, Jul 3, 2002.
  1. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    I am considering buying small speakers (Tannoy R1) to use with a sub (Paradigm PS1000) instead of floortanders and would like some opinions as to what quality of sound should i expect to get. Will small speakers + sub be any good for muic/movies or should i get the floorstanders?
  2. Jase
    Jase
    Mar 16, 2001
    10,723
    United Kingdom
    +2,497
    Arguably a decent sub and bookshelf speakers will outperform a pair of floorstanders with no sub. But it does depend on the speakers used. All THX speakers are sub/sat systems.
    The answer is to demo the different types and choose what you think sounds best. You´ll still need a sub even if you go for floorstanders as not many can plumb the depths that a subwoofer can.
