Bookshelf speakers sound better when standing up
Discussion in 'Hi-Fi Stereo Speakers' started by JRNGRBR, Aug 22, 2018.
  1. JRNGRBR
    JRNGRBR
    Aug 22, 2018
    4
    Netherlands
    Hi there, I recently bought a set of two bookshelf speakers, q-acoustic 3020i. They are positioned about four meters from my couch and set on ear height when sitting. Now when I'm standing up, the quality of the sound seems better, fuller and has more punchy bass. I'm trying to understand how this can occur and if anyone would have tips so I'll have the same sound when sitting down. Can anyone advise? Thanks!
  2. KenM10759
    KenM10759
    Oct 18, 2015
    600
    47
    Spencer MA USA
    +145
    Get shorter stands. :)
    Room acoustics. probably. You can either get measurement and calibration equipment, or just experiment with changing things up, adding acoustic panels and/or bass traps, and stand height.
  3. gibbsy
    gibbsy
    May 17, 2007
    14,442
    3
    Cwm Cynon, De Cymru
    +8,304
    Nothing more than room acoustics, although sitting four metres away from these relatively small speakers may be a tad too far.
  4. blue max
    blue max
    Apr 12, 2006
    12,956
    London
    +4,330
    Really no expert, but couldn't you angle them down slightly? That might be enough.
  5. Paul7777x
    Paul7777x
    Jul 23, 2016
    3,258
    North east. U.K.
    +1,159
    Have you a photo of the setup?
  6. BlueWizard
    BlueWizard
    Jun 19, 2007
    22,621
    +4,305
    Likely you are in a floor to ceiling Null; a vertical null. Shift the position and angle of the speakers and see if you can improve it.
    A photo of the room would also be helpful.
    I had the Q Acoustic 3020 in my room of a while, and they sounded fine. But while my listening room is 16ft x 16ft (5m x 5m) with an 11ft (3.5m) seating distance, the entire space is 16ft x 35ft (5m x 11m). And I have vaulted ceilings.
    It is also possible that rather than sitting in a Null, when you stand you are moving into a Node, which is the opposite of a Null. You are moving into a space when there is an overlap is re-enforcing frequencies.
    This video will help explain what we mean by Nodes and Nulls -
    How Acoustical Panels Improve Sound |...
    Steve/bluewizard
