Bookshelf speakers for Marantz amp
Discussion in 'Home Cinema Speakers' started by sm0akes, Aug 21, 2003.
  1. sm0akes
    sm0akes
    Jul 4, 2003
    My current setup consists of:
    soundblaster live 5.1 computer soundcard
    Marantz pm4200
    Wharfedale Diamond 7.1 speakers
    The treble currently has a harsh edge which ruins many vocals and so i want to replace the speakers as i am pretty sure they are at fault. I want ones that wont have any harshness in the higher frequencies and will have a deeper bass.
    I have discarded any Mission speakers at this stage as i have heard Marantz and Mission will just accentuate the problem - is this true?
    Models i have been considering are:
    Wharfedale 8.1
    Kef Cresta 2
    Tannoy R1
    Thanks for any advice.
  2. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    The Wharfedale Diamond Series are all front ported so they tend to work rather well on bookshelves/close to walls. With that I'll recommend the Diamond 8.1 speakers.
  3. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    I'd be more inclined to look at replacing your soundcard first - the SBLive! 5.1 has a pretty abrasive high end. Couple that with the HF artifacts caused by poor 44.1=>48kHz upsampling in the driver and you've likely got the main contributer to your problem.
    MuFu.
  4. sm0akes
    sm0akes
    Jul 4, 2003
    Thanks for the info, i will try my system with a friends sony 530 cd player and see if it improves things.
    Are there any high-end soundcards that would be suitable that arent really expensive?
  5. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    The M-Audio Revolution 7.1 and Creative Audigy 2 are both well under £100 and offer considerably better analogue output quality than the Live, more so in the case of the former.
    MuFu.
