Bookshelf speaker wall brackets!
Discussion in 'Home Cinema Buying & Building' started by luap1983, Mar 10, 2013.
  1. luap1983
    luap1983
    May 18, 2010
    37
    Hi everyone, can anyone recommend wall brackets for dali zensor 1, They are for my rears! (Not to expensive)
    Also where would be the best place to mount them on the walls? I have a small lounge and my sofa is right back against the wall! I was thinking as far back as possible but on the side walls about 6 foot high pointing down at the listening area! Any advice would be much appreciated!
    Any
    (Title speaker not soeaker) lol
  2. luap1983
    luap1983
    May 18, 2010
    37
    Please anyone!!
  3. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    If your sofa is against the wall then putting them on the walls besides you, slightly behind if possible, about 1m above seated head height is a typical position (more info on Dolby and THX websites for speaker positions).
    I can't help with brackets as I don't know your speakers, but there are loads of speaker brackets on ebay, pick some that you like the look of and fit your speakers?
  4. luap1983
    luap1983
    May 18, 2010
    37
    Thanks mate, should I face them at an angle pointing down at the listening area?
  5. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    If you get brackets that allow you to move the speakers left/right up/ down you can try straight out or angled down - you can see a good range here: Speaker Brackets - Audiovisual Online - Home Cinema and Hifi Specialists - I prefer the ones that have a swivel/ ball joint but access to the back can be a bit more fiddly.
    Speaker placement:
    Dolby Home Theater Speaker Placement and Setup Guide
    I had a quick google of your speakers - they get good reviews :) I found monopole speakers too directional for side surrounds so I switched to bipole speakers but give it a try and see what you think.
  6. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    Thread title corrected... BTW if you edit your post and go advanced you can edit your own thread title.
    Curly
  7. snow-munki
    snow-munki
    Nov 29, 2003
    660
    +17
    Hi, what wall mounts did you end up getting ?
    As I have the exact same speakers and same requirements :)
    Thanks,
