kinga90
Hi there!
I'm looking to replace the front channel and center channel I currently have in my setup.
This is what I'm currently running:
-Denon avr-x3700h
-SVS SB-1000 PRO
-HiVi Swans M200 MKii (as active front channels)
-Klipsch R-52C
Unfortunately due to the current room setup, I can't go over the basic 3.1 but I have to admit I'm already enjoy this basic setup over the basic tv A LOT!
My main concern was to replace the Swans since they are active speakers and they're not really meant to be used in a home theater(as far as I know). I bought them something like 4 years ago and I was using them on my desktop workstation and I now repurposed them for home theater use.
The Klipsch center on the other hand, is just something I wanted cause I really, really loved the Klipsch aesthetic. If the new front channel speaker might require an update of the center as well, I'm up for it.
I mainly use the home theater to watch movies, then I'd put games on PS5 and music on the same level.
I'm attaching a rough drawing of the current room and tv/couch setup
Unfortunately at the moment there isn't much I can change other than the distance of the couch from the tv and the distance of the front channel(limited at the moment from the interconnect wire of the swans that limited me to 1,4m).
The opposite half of the room is taken from the covid home office so ther's nothing I can do there
-Denon avr-x3700h
-SVS SB-1000 PRO
-Klipsch R-52C
