Books on I-pod
Discussion in 'Headphones, Earphones & Portable Music' started by RobertClem, Jan 16, 2008.
  1. RobertClem
    RobertClem
    Dec 4, 2006
    12
    Thinking about buying an I-pod for my CD collection etc. But also to get talking books from the library and put them on to listen to on holiday. Is this a feasible, and if I had say 10 hrs of tunes and 12hrs of books whould the 4gb model be big enough?
  2. Didds
    Didds
    Aug 6, 2005
    397
    28
    +57
    It depends what bit rate you rip the cd's. If you rip to mp3 at a Bit Rate of 64kbps (which should be good enough for most audio books), 1hr of audio equates to about 23.5mb's. 1Gb = 1024mb.Music cd's I wouldn't rip any lower than 128kbps, as you'll lose a lot on the qualitity front. So yes ! :)
    Remember that the 4Gb model will be less than 4Gb. (software and 1Gb=1024mb)
  3. kevH
    kevH
    Oct 11, 2004
    833
    Live Leeds Work Chesterfield
    +37
    As Didds has said youll be fine you should actually get quite a few on there and in my experience dont rip any lower then 32kbps as the audio quality suffers quite a bit. All my audiobooks are ripped between 32 - 64 and play fine.
  4. RobertClem
    RobertClem
    Dec 4, 2006
    12
    Thanks for the advice. I expect to be useing I Tunes to put things onto the I-pod can you set the level to rip books with that or is it done automatically.As you can tell I am very new to this technology.
  5. Didds
    Didds
    Aug 6, 2005
    397
    28
    +57
    Start itunes - Edit - Preferences - Advanced - Importing
    All your setting are there.
