bookmarking using the Panasonic DMR-E500H
Discussion in 'Blu-ray & DVD Players & Recorders' started by gpar123, Nov 14, 2004.
  1. gpar123
    gpar123
    Is it possible to bookmark a DVD using the DVD recorder Panasonic DMR-E500H?
  2. MuffKing
    MuffKing
    Not sure how you mean bookmark, but you can create markers (chapters) on DVD-RAM and HDD.
  3. OARDVD
    OARDVD
    Jul 6, 2003
    241
    16
    Deepest Hertfordshire
    And on DVD-R.
  4. MuffKing
    MuffKing
    Unfortunately you can't create your own markers on DVD-R if you intend to finalise the disc though as the machine creates its own every 5 minutes.
  5. gpar123
    gpar123
    Thanks for you help.
    What I actually meant was if it is possible to bookmark while watching a film so that you can find exactly the same place when you want to continue watching the film at a later date.
    I am new to panasonic and had a pioneer before where bookmarking was possible.
    Regards,
    George
  6. MuffKing
    MuffKing
    Unfortunately the Panny's will only create them on playback, but I see what you mean.
  7. OARDVD
    OARDVD
    Jul 6, 2003
    241
    16
    True - if you add them directly to the DVD-R. But not true - if you add them to the title on the HDD prior to a HS dub to DVD-R, then you'll find that it retains them. It will lose them if you do a real-time re-encode though.
