bolt sizes for hs50 mount
abs
finally took the plunge and got myself a hs50, excellent pj. i am looking to mount it on the ceiling. does anypne have any idea what size bolts i will need?
RTFM
If you look in the instruction manual at the back it should tell you the size of the captive threads. Typically M4 or M5.
Make sure they are not to long as you can damage internal PCBs on some projectors.
Jeff :rtfm:
