Boiler Pressure
Discussion in 'General Chat' started by Member 328449, Mar 11, 2013.
  1. Member 328449
    Member 328449
    Aug 31, 2007
    3,431
    Kent
    +342
    My boiler pressure is at 0. I've tried fiddling with the levers and nothing seems to help. Any advice?
  2. Wahreo
    Wahreo
    Oct 11, 2012
    15,332
    +12,505
    Black lever?
  3. Member 328449
    Member 328449
    Aug 31, 2007
    3,431
    Kent
    +342
    Turned it both ways. No change.
  4. Wahreo
    Wahreo
    Oct 11, 2012
    15,332
    +12,505
    from the picture, turn the black lever on the right so it is in-line with the pipe (90 degrees to what it is now) then turn the black lever on the left 90 degrees.
  5. danmc_82
    danmc_82
    Jan 19, 2007
    5,627
    Skynet Border
    +1,206
    Normally takes two levers to fill system, you tried both?
  6. Member 328449
    Member 328449
    Aug 31, 2007
    3,431
    Kent
    +342
    That's done the trick! Thanks very much. Is it safe to leave it like that or should I turn one/both of them off until it needs topping up again?
  7. Wahreo
    Wahreo
    Oct 11, 2012
    15,332
    +12,505
    Deffo turn them off after filling!!
  8. Member 328449
    Member 328449
    Aug 31, 2007
    3,431
    Kent
    +342
    Both of them?
  9. Redline
    Redline
    Oct 9, 2006
    1,411
    Weymouth
    +341
    Try this video. Not sure about disconnecting the filler pipes though. I don't bother.
    Its always two levers to fill the system.
    How to repressurise or fill a combi boiler or...
  10. Wahreo
    Wahreo
    Oct 11, 2012
    15,332
    +12,505
    Yes.
    It's a sealed system therefore it needs topping up manually when the pressure has dropped.
  11. Member 328449
    Member 328449
    Aug 31, 2007
    3,431
    Kent
    +342
    Thanks very much for the help. All sorted now.
  12. jonna
    jonna
    Mar 25, 2002
    3,206
    Cheshire
    +2,529
    What is the reading now?.
  13. paulyoung666
    paulyoung666
    May 4, 2006
    13,510
    Teesside
    +3,841
    you need to know why it has dropped in pressure and that fixed pipe should be a filling loop that can be removed after the pressure is increased ...
  14. danmc_82
    danmc_82
    Jan 19, 2007
    5,627
    Skynet Border
    +1,206
    Did you bleed the rads?
  15. reevesy
    reevesy
    Feb 20, 2005
    6,226
    +2,111
    as mentioned a loss of pressure normally means one thing...a leak somewhere.....only needs to be a 'weep' and pressure will drop eventually.
    check all your pipes/connections and radiators........leave a few bits of tissue laying about under any suspects...any drops will show up on that
    theres a really good central heating problems/questions thread in general chat if you've not already seen it......the guys good at the old fault finding
    http://www.avforums.com/forums/gene...-central-heating-boilers-feel-free-ask-5.html
