bogging comp down
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by lexx, Nov 11, 2003.
  1. lexx
    lexx
    i started to put together a home video a while ago and lately everytime i add music, delete music, or try to watch the video it freezes windows movie maker. ya i know probly not top of the line in any respect but i didnt care enough to find another editing program. i have a p4 2.4ghz 512mb of ddr ram and an 80gb hard drive my comp is bran new (i built it :D ) and its not the ram because i have a program that tells me how many mb of ram i have left and when i was editing it said 300mb. do you know why its freezing?? thanks in advance
  2. Mike Swannick
    Mike Swannick
    If your XP install is FAT32 and not NTFS, your video creation file size could have hit the maximum file size limit of 4Gb maybe?
    I'm sure that I suffered from that prior to reformatting.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    When video editing on a PC you really do not want any other programmes running other than those needed for the job. Before you start you should stop ALL background progs. such as anti-virus and memory usage etc. The reason for this is that editing stretches the i/o of an IDE drive very close to its limit. In an ideal world you would have all your captured footage on another drive.
    Few other things to check:
    As mentioned above, make sure the drive is formatted to NTFS.
    Make sure DMA is enabled for the drive(s)
    Try to avoid haveing a CD/DVD drive on the same IDE channel as your capture drive
    Make sure the IDE cable is a full EIDE cable and not just IDE (ie for CD/DVD)
    A good programme that I use to stop all background progs is EndItAll. Do a search on Google etc for it. It is a free download and works really well.
    Mark.
    ps, if not already, upgrade MM to MM2. Its free from the MS web site.
  4. swilt
    swilt
    It probably is one of the above suggestions but it would be worth posting it on the moviemaker newsgroup, they have helped me loads recently.
