bog standard DVD+r recorder needed
Discussion in 'Blu-ray & DVD Players & Recorders' started by dapex, Sep 2, 2005.
  1. dapex
    dapex
    Jul 21, 2003
    1,082
    38
    +11
    Can anyone suggest a nice cheapish dvd+ recorder? I dont need a HD as i have sky+, I already have an oldish philips dvd recorder but its decided to stop playing dvd's and so it needs replacing..
  2. alan8477
    alan8477
    Dec 17, 2001
    593
    Pershore
    +11
    If cheap and +R are the most important then possibly:
    {HA 4143} Sumvision SV-1001 DVD Recorder with DivX/Xvid Compatibility
    can be found at:
    http://www.blankdiscshop.co.uk/acatalog/dvdrecord.html
    for £87.54 incl. VAT
    I do not have a clue how good it is, or whether it will be able to handle your old Philips discs etc, but it's cheap and is +R(W). I was also a previous Philips user (machine no longer working), but decided to bite the bullet and ditch +R and went for the Toshiba XS34. Pleased I did.
