if you've got a strong beam - then I would recommend some gymnastic rings as they're very good for strength...but there are some good routine on the web for just using your body weight - like do a search on youtube for metafit
I do a class on a friday night...tho, it's mainly a cv workout, but is hard going (but then I do it after a 40 minute kettlercise class!)
and there is the likes of the 100 pushup challenge website - as they have other exercises like squats, dips etc - one hundred push ups - welcome
I have the Powerbar 2: http://www.amazon.co.uk/Powerbar-as...F8&qid=1365418395&sr=8-1&keywords=power+bar+2
It's solid and barely leaves a mark on the door. Nothing major anyway.
Also the JML Iron Gym is a popular one, although I prefer the Powerbar 2 as it goes higher-- the actual bar is above the height of the door frame so better for taller folks.
For Bodyweight routines, you could check out Ross Enamait's website (Rosstraining.com). I haven't used it myself but it seems to be quite popular. I do bodyweight stuff at home: pullups, one arm pushups, handstands, and various things on rings which I attach to the pullup bar (dips, rows, levers etc). I also have a kettlebell which is pretty awesome for strength and conditioning and it allows you to do some intense cardio without going anywhere or jumping on a hamster machine. I'm loving kettlebell swings and Turkish getups at the moment.
well, pushups would only be a fraction of your overall workout...but they are good for strength - but as ninja said - get a kettlebell...or you could try with a dumbell with limited success...
depends on what your overall goals are - to get stronger, bulk up, lose weight?
there are a ton of exercise routines on youtube , i like this lot ( I do their cardio routine up the gym although they can be done at home just as easy )
Welcome to the 6 Week Six Pack Challenge!
be warned though its not easy![]()
