Bo Selecta + Sony dvd player problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by simon1, Dec 21, 2003.
  1. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    Just got the Bo Selecta box set for xmas (yeah, opened it early). The 1st series disc is not working correctly on my Sony Dvpns700 player.
    It plays each episode without problem, but when you try to select most of the extra features - the player gives the C:13:00 error message and displays a blank screen.
    The 2nd series, both discs work fine.
    I wonder if this is a poorly/faulty manufactured disc or is it branching problems? I've not experienced C:13:00 errors before, so I hoping it's not the player.
    I noted that on the 1st series disc, it won't display 'time remaining', which I found odd.
  2. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    i had this once on my ns 705 then aweek later the dvd player died (the drive that is )quoted £65 !!!!!! mmmmmmm sony dvdr
  3. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    In what circumstances did your player report C:13:00?
    Was it happening often?
  4. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    Panic over - Just got the disc swapped this morning at woolies...................................................and it works!!!
    Never had a faulty disc before and expected the replacement to do the same, thinking it was my player at fault.
    Can't say how releived I am.
