Question BNC v Ethernet CCTV system
bartjunited
HI all I need a basic 3 camera cctv system.
I currently have a couple of Ring wifi cameras which I dont like and arent very good as they are slow to respond and most of all at a glance you cant see all cameras as you would with a cctv system
Ive been looking at Swann and HIK systems using BNC cables as if i used an IP based system I wouldnt be able to run a cable direct to my router and would have to use a powerline adaptor to connect my box to the router. PLus if i had to make the ethernet cables longer or shorter i dont know how to crimp to do that.
So Im looking at some BNC systems
My questions are
For my simple set up is BNC ok?
If I use BNC cables and run the cables outside the house would I need to put them in trunking?
If an IP system is better what would you recommend and could I use a Powerline adaptor to connect the box to the router and all cameras will have a direct cable to them?
TIA in advance
Bart
sbriggs
How are you intending to view the images from the cameras , are you intending using a dvr/nvr
If you are looking to view them on a phone or other network device then cameras run on BNC will have the same issue as you will need to connect the DVR to the network
If you are looking to just view directly on the NVR/dvr then neither IP cameras or BNC cameras necessarily have to be connected to the router
bartjunited
I would like to view the images on my phone and possibly a TV. As I'm intending the box to sit in the loft I could run a hdmi cable to a TV in an upstairs bedroom too?
sbriggs
Whether it a dvr with BNC cameras or a NVR with IP cameras makes no difference for the connection to the router . Cabled would be ideal but powerline is an option for both
bartjunited
Thanks is NVR the network video recorder for up systems?
With the above in mind would you recommend a BNC OR IP systen?
My assumption is with IP system is that it's 1 cable to each camera from the NV which carries power and audio/video is that right?
Anything you can recommend in the £300 range?
sbriggs
Yes NVR is network video recorder , I would recommend IP cameras
Yes 1 cable from NVR to each camera carries power and video/audio
3 decent cameras and Decent NVR for £300 will be tricky , we only use professional kit and would be more like £500 . Will also depend on resolution required and amount of storage
bartjunited
Tbh storage is not an issue I'd be happy to see 7 days which is probably a lot more than I need I really want just day to day.
Resolution again open to options I think 2MP would be OK 5 would be better. As this is a home install and I'll be doing it myself hence the budget.
Why IP over BNC for small jobs?
With ethernet or BNC cables would they need to be trunked if they are running outside the house?
sbriggs
Ethernet cables and therefore IP cameras can carry higher resolutions so more future proof , also easier to setup and manage imo.
It doesn’t affect the price greatly really when you take everything into account
bartjunited
What brands would you recommend? I've been looking at Swann and HIK Vision?
Do I need to trunk an ethernet cable if its outside or can I just cable clip it due to weather?
I could possibly run a ethernet cable from the loft to the router if I can cable clip it outside the house
sbriggs
Ethernet cable Or BNC cable needs to be external grade if just cable clipped.
We use aspect , lots use Hikvision , Swann I find is just a product to hit a price point .
I would say spend a bit more and have a system that is good quality or not worth having / false economy
sbriggs
We also use UNiFi however may be outside OPs budget . 3 cameras , cloud key with 1tb and Poe injectors over £600
Mr X
You could do the following
Cloudkey £190 includes 1TBstorage
3 cameras @ 144 each (G3 Bullet or Dome) £432
or £74 each (G3 Flex) £222
(Or mix cameras)
8 port switch including 4 POE ports £49
So cheapest option for above would be around £460 plus Ethernet cable.
The cameras listed though can go outside but only recommended under eaves or guttering
You will be able to view and control footage from any PC/Mac, smartphone or a media streamer such as Apple TV. No subscription charges.
If you want to add a monitor or TV for always on viewing you will need to add a product called Viewport which adds HDMI port over POE (Optional but around £160 from memory)
It may seem a bit daunting but one of the easiest things I’ve ever put together and just works.
bartjunited
(Or mix cameras)
Thank you so much for putting that together
I was thinking of actually putting cameras at the top of the house under eaves for ease of installation it would just mean that I can only put them on the front and back of the house and not the side but that might not be too much of an issue as the side of the house is very small and if the front camera is wide enough it could cover the side.
Does this integrate with alexa or google assisant? If I could watch ity via a firestick that would be great too
Similar threads
Podcast: Panasonic HX800 TV + Sony HT-G700 Soundbar reviews, movie and TV show news and reviews
Trending threads
Latest News
MBL brings high end Hi-Fi systems and speakers to UK
  • By Andy Bassett
  • Published
Roku announces Streambar and adds Airplay to streaming devices
  • By Andy Bassett
  • Published
Amazon Prime Day confirmed as 13-14th October
  • By Andy Bassett
  • Published
Linn upgrades Majik LP12 turntable with new tonearm
  • By Andy Bassett
  • Published
VPI announces new Prime 21 turntables
  • By Andy Bassett
  • Published
