BNC Connectors
Discussion in 'Home Cinema Building DIY' started by molipa, Aug 15, 2002.
  1. molipa
    molipa
    Aug 14, 2002
    33
    Bristol England
    Can anyone tell me the difference between RG58 & RG59 BNC plugs,i'm looking in a catalogue and they look the same.
    Thanks.
  2. crtbob
    crtbob
    rg58 are 50 ohm connectors
    rg59 are 75 ohm connectors
  3. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,279
    Manchester
    +762
    Absolutely correct.
    50 ohms is generally used for communications/RF
    75 ohms is the norm for video connections.
    If you could see 1 of each BNC side by side, you could tell that the dimensions are slightly different (in order to achieve the correct nominal impedance).
    Chris Muriel, Manchester.
