Question BMW E88 - Afternarket Head Unit & Reverse Camera - NO IMAGE
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by Ash14297, Aug 27, 2018.
  1. Ash14297
    Ash14297
    Aug 27, 2018
    4
    United Kingdom
    Hey all,
    So... I’ve sucessfully installed a double din stereo in my E88 (which was an absolute pain in the a$$). Latest project is installing an aftermarket reverse camera since my Pioneer SPH-DA10 supports this.
    I bought a BMW intergration one off Amazon that replaces the boot open button. Installed the whole thing today... low and behold I have no image displaying on the screen [​IMG]
    Pretty simple setup
    - Reverse camera has one long cable, at one end is a red and black wire (positive and ground), and the other end is the RCA connection into the radio and another red wire (reverse detection wire).
    - Reverse detection wire not needed since Head Unit is connected to a Connects2 harnus which retains canbus functions (so Reverse wire is already connected using that).
    - RCA cable plugged into brown CAMERA IN on the back of the head unit
    - Red wire at the other end is tapped into the reverse light positive wire (black/purple wire), and black is connected to reverse light ground cable (brown wire).
    Reverse detection is working because when I go into reverse, the head unit switches to reverse camera mode. However, I get no image whatsoever. Just a black screen with parking aid lines.
    I have read that BMWs have a pulse voltage to the reverse lights that may not be providing enough power the camera - however, it seems In most instances the the image still usually displays but is very “flickery”. I have nothing at all which is making me question if it’s something else causing this...
    Is this going to be a relay installation job? Or am I missing something?
    Ash
  2. gibbo52
    gibbo52
    Nov 30, 2014
    158
    Leicestershire
    +36
    I'd try the reverse detection wire.
