BMW 3 Series ISO connectors????
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by Messiah, Dec 8, 2004.
  1. Messiah
    Messiah
    Apr 22, 2002
    7,534
    +339
    Anyone know if the BMW 3 series (2003 model) radio (Business MD) has std ISO connector blocks at the back?
    I want to fit a Parrot GPS/BT kit which comes with ISO connectors on the harnesses and be great to kow before I start pulling the car apart :p
    Thanks :smashin:
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,785
    Norwich
    +667
    No it doesn't, it has their own connector.
    Connects2 do a phone install adapter that just slots in between the bmw connector and the head unit, this will give you everything you need to install the parrot kit, including power, mute and routing it through the front speakers of the car.
  3. Messiah
    Messiah
    Apr 22, 2002
    7,534
    +339
    Thanks. Again :D
    Connects2?? Any idea who sells them?
  4. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,785
    Norwich
    +667
  5. Messiah
    Messiah
    Apr 22, 2002
    7,534
    +339
    Thanks. Just spoken to my local Uplands Car Audio store and they say they have an adapter kit. Gonna pop in this afternoon with the Parrot kit and if it's the one I should be fitting it tomorrow.
    I've worked out how to get the radio out (though broke the clip on the rhs of the carbon look trim :mad: ) so now just need to work out where to fit the display and where / how to route the cables :confused:
    Thanks for your help :smashin:
