BMG Copy Control
Discussion in 'Headphones, Earphones & Portable Music' started by Big Al, Nov 22, 2004.
  1. Big Al
    Big Al
    Jul 13, 2000
    247
    Sandhurst Berkshire UK
    I'm fairly new to the world of digital music, and have slowly been ripping my collection to a spare PC which will act as a wireless sound server to the whole house.
    Im having problems ripping a cd (Life for Rent) with BMG Copy Control. Does any one know a way I can get this disk on my PC?
    Big Al
  2. rscott4563
    rscott4563
    Jan 21, 2003
    1,051
    38
    Cumbria
    I'd also really like to know the answer to this as I've got a number of CD's which wont let me rip them to my PC, I've been trying with MS Media Player but would be willing to use anything as long as it let me rip to a compressed format with CDDB info.
    Ryan
  3. Matthew Attoe
    Matthew Attoe
    Dec 8, 2001
    695
    Norwich
    +11
    Willing to use anything, eh?
    Try a Mac running OS X. I've never come across a copy-protected cd i haven't been able to rip yet, inluding the aforementioned life for rent.
    Another small victory for the Mac user :) :) :)
    Cheers,
    Matt
  4. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Hold the control key down then you can rip it
    I do not buy BMG anyway as I cannot play them in the DVD player
  5. detailmeister
    detailmeister
    If you disable autoplay on the CD drive the copy control software on the so-called CD will not load. That usually lets your ripping program access the CD properly. Holding down CTRL when you insert the disc has much the same effect, 'cept it's hard to guess how long to hold the key down for.
    However if the copy control CD has permanently loaded some software on your PC then you will have more difficulty.
    Detailmeister.
  6. stuart-f
    stuart-f
    Aug 6, 2000
    45
    9
    Saint Paul-en-Foret, Var, France
    Try downlaoding iTunes and use that. I could never get the 1st track from the Kings of Leon's first album using anything else but iTunes worked a treat.
  7. Big Al
    Big Al
    Jul 13, 2000
    247
    Thanks guys
    The control key method worked a treat.
    Regrads
    Big Al
  8. richmark
    richmark
    Any ideas how it can be removed? The control key method hasnt worked...
  9. Arfa
    Arfa
    Apr 25, 2006
    1,071
    London
    +71
    Sounds like a faulty CD to me, perhaps you should take it back...
    Does the cd have this label:-
    [​IMG]
    If so, you could contact trading standards, as they're marketing it as a CD that adhears to the CD standard when it blatently doesn't.
    Otherwise try ripping with EAC.
    Although I suspect the disabling of auto cd play is your best plan. There's an article from M$ on it here: http://support.microsoft.com/kb/155217
  10. Autopilot
    Autopilot
    Feb 5, 2005
    7,138
    Region 2
    +1,266
    DBpoweramp will rip these too i think, anyone confirm?
    Otherwise, there's programs that you can run that remove it silently in the background and allow you to rip with any app you want.
  11. Off The Fence
    Off The Fence
    Nov 1, 2003
    218
    North West London
    +11
  12. lazymatt
    lazymatt
    Oct 23, 2006
    1,996
    Croydon
    +188
    iTunes seems to work o.k. I always had problems with Kings of Leon except with iTunes as well.
