HiFiRuss71
Now, this bit seemed to cause some debate (i.e there was literally no in between on the opposing opinions) on a popular DIY Speaker Facebook group and one that is waaayyyy less combative than almost any forum. What have I done? I have damped the rear surface of the horn. Shock!
One stance is that by the time you have bolted 2kg of tweeter to one end and screwed the mouth to the baffle, the horn will be well damped and what I have done is unnecessary. The other stance is that people can't understand why you wouldn't do it.
I'm in the latter camp and feel I do understand why you should do it. I did it on the mid horn of my Klipsch Forte IIIs and it definitely made than sound a bit cleaner and less 'busy' when playing out high volumes and I do mean high - 100dB+ peaks on music sounds a lot louder than it does in home cinema.
What it cannot do is make anything worse and as I was staring at more than enough spare Silent Coat to make it work, why not? You decide - opens link to Facebook.
