bluray...
denon007
everybody, i'm having trouble getting sound from my bluray to amp it just
say's Mutli channel!!!
has anyone got any ideas.. i have tried the manuals even rang the shop i
bought the bluray from they had no answer's It's a denon 2012 bluray and
A denon 3312 receiver.
Would be grateful for any idea's.:lease:
andy1249
How are you connecting the two ?
With those models you have a number of options , you can go analog output from blu ray to analog inputs on the amp , this would be the "Multi Channel" option.
That requires at least Six analog RCA connections depending on whether you going for 5.1 ( 6 Channels) or more in your setup.
Then you have the optical or co axial digital outputs , those could be used but the interface cannot do HD audio codecs so those are best avoided.
These will require you to "Assign" inputs on the amp though , not usually a straightforward procedure at all , with any amp.
The Best and easiest option though , would be HDMI from BD player to amp , and the BD player should be set to "Bitstream" to the amp.
Make sure you have the right HDMI input selected on the amp , and the right HDMI input selected on your screen , and then turn on the BD player , it should be pretty much automatic after that.
Samsung & LG UK TV Prices 2023; Amazon Fire TV Cube; Calibration Tools of the Trade + AV news
