Question Blur reduction feature missing on the 43 model
Discussion in 'LCD & LED LCD TVs Forum' started by MihneaNic, Dec 4, 2016.
  1. MihneaNic
    MihneaNic
    Dec 2, 2016
    26
    Geneva
    I have a the samsung UE43KS7580 model.
    The blur reduction feature of Auto motion Plus don't appear in the menu. The 55 model have it.
    Is it a bug in the firmware or all 43 models are missing this feature ? I am waiting for a repsonse from the samsung support.
    Also after my readings, blur reduction is motion interpolation ONLY for video content (tv shows). For movie content (24fps) it is not used, judder reduction is used instead.
    Is that true ?
    My question is : is that so imporant ? should i change my tv with one having the blur reduction ?
