Blum soft close mechanism
anticlaus105
Some of my kitchen cabinets have these fitted. The ones that do only have them on one hinge. I was going to buy some for the ones that are missing. From what I can gather they don't really do anything. To me the doors without are the same as the ones with, I can't tell any difference in how they close. Should there be one on each hinge i.e. 2 for each door? Can they go defective over time and need replacing?
Maybe if I should just buy 1 pack and test them.
27neth
They only close slowly for about the last 20%.
They do wear out over time, replace the hinges with this type instead.
27neth
You will get them cheaper than that, it was just the first link I found :D
Thats also for a pair, you don’t need the standard hinge
They are about £3 on EBay
IronGiant
Thanks, I was thinking I might upgrade my doors with them and it came to £260 inc VAT :rotfl:
Amazon Fire TV Cube Gen 3 Review: Coming Soon
