Bluetooth transmitter optical/jack
Delore
Have a transmitter and a couple of pairs of headphones with aptx ll coming tomorrow that will be used for TV/movies and wondering what would be the best way to connect the transmitter to my set up.
My options are optical or headphone jack into the TV (B8 oled), or into the front headphone jack on the Yamaha AVR. Will there be any difference in sound quality between them? Just wanted to check so I can run the appropriate cables today while I'm off.
JayCee
In theory using optical from the TV should give the best quality but in practice there's usually no noticeable difference between it and the headphone output.
Delore
Thanks, I'd hoped that would be the case. Was doing some testing earlier for setting up a harmony activity and using the headphone socket on the TV was probably the best solution, although I'd need to manually set to headphone output (too many steps for harmony to navigate menu without messing up) it automatically goes back to Arc when the AVR gets switched on. If set to optical it just stays on optical.
Podcast: LG C1 OLED + JBL Synthesis SDR-35 First Thoughts, plus TV Show & Disc Reviews & more
