PCs, not that it matters as the ability to pair with multiple hosts needs to be within the mouse.What are the 'devices'?
Thanks.Not much help, but to save you looking into them, I know you can't with any Logitech ones.
Well it needs to work across the room & the regular wireless versions tend to have (IME) quite a limited range. I'm pretty sure that a non bluetooth device couldn't pair with multiple PCs but having a pair of BT headphones that can, I at least know it's possible with BT.Do you really need Bluetooth?
The Logitech Ultrathin Touch Mouse (T630) is Bluetooth and supports 2 connections (one at a time) The T631 is the same but for Apple vs Windows
I use a BT mouse of the laptop & it would be useful if I could shut down the laptop, power on the TV PC & use the same mouse. I'll just buy another mouse.
