Bluetooth Headsets
Discussion in 'General Tech & Gadget Forums' started by richjthorpe, Jun 22, 2005.
  1. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Is it possible to use a bluetooth headset to connect to a PC and use Skype to call instead of having a headset or needing the Skype phone ?
    Cheers,
    Richie.
  2. Kalef
    Kalef
    Sep 24, 2002
    Devon
    +3
    richjthorpe, yes it is possible. I am using skype with a Jabra 250v connect to my mac & it works perfectly. :)
  3. Embarker
    Embarker
    Apr 19, 2004
    1,676
    Garden of England
    +70
    Is there an idiot guide to getting this working for poor windows users!?!
    As I understand it you need the widcomm drivers and not the ms bluetooth drivers, but that is as far as i've got..........
    Dave
  4. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    36,306
    10
    13
    CyberSpace
    +10,793
    Widcomm vs MS does depend what hardware you've got etc...The MS ones do support the Audio profile as well so there shouldn't be a problem...
    To start ensure you know how on your hardware (there are so many variations) you can set Windows to search for bluetooth devices...Before you do that make certain your headset is in discoverable mode...Once Windows found it, it will list the profiles that are available...It should become obvious then....
    There is a catch though, not all headset support being connected to more than one device. So if you have already paired it with your mobile it may or may not work until you break that connection....That's one of the things that separates the good ones from the cheap and nasty ones...
