pedropeter
Just wondering if anyone can through some light on this puzzling issue.
I have been using my Walkman A55 for a number of years, using a range of bluetooth speakers and headphones.
When compared to my Android phone I've always found the audio quality about the same ie no noticeable difference.
However, I have recently bought a cheap but powerful W-King bluetooth speaker for outdoor use. For the first time I am hearing a big difference in bluetooth audio quality from the Walkman compared to my phone. The Walkman sounds flat with very little bass.
Conversely the Android phone sounds well rounded with punchy bass.
Note, when I use a bluetooth receiver plugged into the W-King 'audio in', the Walkman sounds fine. So the problem definitely seems to be a bluetooth issue only between the Walkman and the W-King speaker.
So to recap, the Walkman sounds fine through all my devices except this new W-King speaker.
But the W-King speaker sounds fine when using my phone or via a bluetooth receiver.
Just to add. I am unable to adjust bluetooth volume on my Walkman when using the W-King speaker, I have to do this physically on the speaker.
So does this add weight to my theory that there is some sort of incompatibility between the two devices.
Thanks for any comments.
