Bluetooth and Nokia 7610
Discussion in 'Mobile Phones Forum' started by DustySox, Apr 14, 2005.
Tags:
  1. DustySox
    DustySox
    Aug 25, 2004
    535
    Wokingham
    +10
    My girlfriend recently brought 7610 as well as a bluetooth car kit (model BH-005). I can get them to communicate, however when either phone or BH-005 get switched off they seem to "forget" connection when switched back on. I thought once they were paired that as soon as in range they would recognize pairing and therefore establish connection. Although when I go into blutooth settings and physically "connect" it then works ok, until switched off. I have tried with my 6310i and all works as expected. So the problem points to the 7610, any thoughts :lease:
    :lease:
    :lease:
    regards
    Darren
  2. DustySox
    DustySox
    Aug 25, 2004
    535
    Wokingham
    +10
    Anyone??
    :lease:
    :lease:
  3. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,357
    83
    +193
    When you've paired them, have you set the handsfree as a "Trusted" device? This could be your problem, as the Nokia won't talk to it (when disconnected initially) unless you allow communications. It's a Nokia thing - it remembers to communicate with my headset but it has to be trusted first!
    Just a thought.
  4. DustySox
    DustySox
    Aug 25, 2004
    535
    Wokingham
    +10
    I have PM'd you but please ignore (think I was asleep when replying!)
    I have looked in handsfree setting (settings/enhancement/handsfree menu on phone), and the only available settings are "default profile" and "automatic answer". I can't find any "trusted" device parameter. Am I looking in the wrong place?
    ATB
    Darren
  5. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,357
    83
    +193
    OK. Definitely in the wrong place.
    Just dug my 7610 out (literally) :)
    From the Main Menu - go to connections, then Bluetooth.
    Push to the RIGHT and you will see a list of paired devices, select your handsfree, then press options. Go down to "Set as Authorised" - it will say that communications will be automatic without having to accept authorisation or something. Select yes. The handsfree kit should now appear with a little padlock to the right.
    That SHOULD hopefully sort itself out (of course, they need to be initially paired first.)
    Let me know if that works or not :)
