Bluetimes MX5 £45.00
planthead
A lot of folks are hearing about android sticks and XBMC, here is a new android box, @ £45.00, running a modified xbmc, and can use the phone as a remote..how it runs is another matter..
Update: from April 8th 2013, all of our MX5 TV Box will be upgrade to Android 4.2 OS
Aliexpress.com : Buy Bluetimes MX5 Dual Core Android Smart TV Box XBMC Media Player Center Smartphone Remote Control AMLogic 8726 M6 Free Shipping from Reliable Dual core Android TV box suppliers on Shenzhen Bluetimes Technology Co., Ltd.
Bluetimes MX5 Specifications:
SoC – AMLogic 8726 M6 dual Cortex A9 CPU + Mali-400 GPU
System Memory – 1G DDR3 RAM
Storage – 4 GB NAND Flash + SD card slot
Video Output - HDMI + Composite
Audio Output – Optical Audio Output (S/PDIF) + HDMI + Stereo RCA
Video Codecs – M-JPEG, MPEG-1, MPEG-2, MPEG-4, H.263, H.264, VC-1, DivX, Xvid, RealVideo, VP6, Sorenson Spark
Audio Formats - MP3, WMA, APE, FLAC, AAC, WAV, OGG
USB – 2 x USB 2.0 host
Connectivity - 10/100M Ethernet (RJ45) + Wi-Fi 802.11 b/g/n
Power Supply - DC 5V/2A
Dimensions – 182 x 135 x 42mm
Weight – 480 grams
Modified XBMC pre-installed, supports XBMC 1080p video playback
With XBMC add-ons, you will get amazing media center experience
Supports smartphone remote control, use your smartphone to navigate/control/inputting on this TV box
Supports 2.4GHz wired/wireless keyboards and mouse/fly air mouse
Supports 5.1 channel AAC audio output via Optical port
Play 3D games, listen online Pandora radio, streaming videos via Netflix
Built-in 802.11b/g/n WiFi adapter with external antenna
1080P video playback(1920 x 1080)
Multi-language supported
USB Webcam and USB Microphone compatible, make Skype video/audio chat
*Official XBMC for Android does not support hardware decoding currently, we pre-installed MX Player and Modified XBMC to enable 1080p video playback in XBMC; Future updating from XBMC will make improvement on hardware decoding
next010
Slightly amusing how not clued in the maker of this box is, the device uses an Amlogic chip which is the only chip supported by XBMC on Android and they instead supply a hacked version of XBMC that replaces the media player with MX Player making it a shell only.
These M6 generic boxes have a ton of problems, if anyone is interested go look at the ATV1200 thread in the XBMC Android sub-forum. Your on your own buying these and pretty much a guinea pig for development/testing.
d64
Hi, I have Bluetimes MX5,and works pretty well but I have problem with DTS sound. Everything is OK by PCM but on OPTI or HDMI passthrough there is no sound on any video playback software. Any advice ?
And a second issue, witch USB video camera work with this crap without additional actions. Just plug and play.
Thx, for any info.
