Bluesound Node vs DAC
NoviceGuy
Hello AVForums:
I'm currently debating whether I need a Bluesound Node or DAC to improve the sound quality of my current system. I'm hoping to get some insights from this forum to help me with my decision.
I currently listen or stream Tidal and Spotify via TV and Echo show, directly connect these devices to amp with optical cable from the TV through GrantFidelity TubeDAc 09 or 3.5mm and RCA from Echo show to A65 ARCAM Plus amp with B&W 606 S2 speakers.
I'm not sure Node is able to improve the sound for my current setup or I should get a good decent DAC to achieve this goal without a streamer.
Thank you in advance.
Nico72
Do you have an optical cable between the TV and the Arcam A65+? Are you sure?
NoviceGuy
Thank you for your question. I forgot to include a GrantFidelity TubeDac 09 piece in my setup above. The TV is connected to the GrantFidelity TubeDac 09 with optical cable, then connect to the amp.
Thank you for helping me to clarity the setup.
